If I lower it... - FirebirdV6.com/CamaroV6.com Message Board
If I lower it...
  • If I lower it...
    I know that when you lower your car that you are supposed to change the shocks as well. However, I just recently put in new shocks (11 Months, 5-8000 miles ago) which isn't brand-new but they are certainly not old either.
    When I put the lowering springs on would it be foolish not to replace my current shocks? I think it would be alright but I'd like to be reasured.
    2002 Red Camaro 3.8L<br />Monsoon stereo with T-Tops
    Re: If I lower it...
    i didnt replace mine and i havent had any problems so far and its been about 10k since i did the swap. i'm going to replace them in may anyway though.
    come get some
    http://www.canyoumaketheturn.com/
      with shocks that new..dont worry about it.
        you would be fine. i changed my shocks and struts one year and then decided to lower her the next year.
        WAWA-A-HOLIC
          Cool, thanks for the help
            but unless your shocks are valved for the lowering springs it won't handle as well as it should, the lowering springs will contantly compress your shocks, and your shocks will constantly be fighting the spings, you run the risk of having a very touchy unstable suspension or an overly stiff suspension (depending on the strength of the shocks and the spring rate)
            I would suggest consenting with sam strano, he is the real suspension guy, he will most likely tell you to have them re-valved
            K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
