I hate... - FirebirdV6.com/CamaroV6.com Message Board
I hate...
  • I hate...
    the rain. Alright, I'm about to cry. My car hydroplaned, twice, almost hit a pole but it just curbed itself.
    My front tire is toed out and my rear tire is toed in. I know I need to get a front end alignment, I hope, to fix the front. ( No sounds or anything, the only one is a VERY loud squeek in the rear tire. )
    What could be wrong with the rear?
    Re: I hate...
    anyone?
      Re: I hate...
      If your rear tire looks mis-aligned then you probably bent the axle. Get it checked out.
        Re: I hate...
        does that require replacing the whole axle?
          Re: I hate...
          I'm not so sure if you can get away with just replacing the axle-rod
            Re: I hate...
            you bent the front tie rod too if not something else as well
            2000 3.8 A4 Pewter Camaro
              Re: I hate...
              rain is KICK *** my front tires are almost bald along with my rear going around corners even at like 10 MPH I can drift its so ****ing fun :D
                Re: I hate...
                If you need some axleshafts I have some.
                  Re: I hate...
                  moses you got some bad luck eh?
                  Follow me!
                  Or this
                    Re: I hate...
                    Yeah, you have a nice amount of damage on your hands. That's really bad luck....(tip 1) don't drive in the rain, that's how rust happens underneath.
                    But, good luck getting her fixed.
                      Re: I hate...
                      If you've got the narrow stock wheels you're pretty fortunate to not have curbed you paint too. So it's not all that bad. :) Good luck fixing it.
                      1998 M5 3.8 Mystic Teal Camaro<br />Flowmaster exhaust, Pacesetter headers, 3\" cat, 3\" S-pipe, whisper lid, ram air, Spec Stage 1 clutch, Poly Trans mount, Walbro 255LPH. Numerous appearance mods.<br /><br /> <a href=\"http://www.cardomain.com/ride/2130533\" target=\"_blank\">http://www.cardomain.com/ride/2130533</a>
                        Re: I hate...
                        I might. lol. It's still raining like crazy out and I just woke up, so I haven't checked.
                        The car isn't really reacting like it has a tons of damage. and the rear wheel you can't tell it's toed in unless you literally lay on the ground and stare at the tire and body of the car.
                          Re: I hate...
                          UPDATE:
                          Front Upper and lower control arm is bent. Rear control arm is bent(?), my axel shaft on the passenger side MAY be bent, not sure. Both of my rims are bent, need new ones. Rear stabilizer bar, bent. and I believe that is it. Oh, my tie rod bar is bent a little, but everything else tie rod wise is fine. - sigh. -
                          Any good places to find these parts? Aftermarket preferred. I'm parking the car for 2-3 months while I save up the cash.
                          Oh
                          Note: My rear passenger side is sitting a LITTLE lower. Muffler Brothers guy ( that I know ) said it may be cracked.
                            Re: I hate...
                            check daytonfbody for the rims. i think i saw some wheels on there for pretty cheap.
                            Follow me!
                            Or this
                              Re: I hate...
                              That's a good excuse to buy some tubular stuff. Drop a few punds and a little firmer feel.
                              Let's flip a coin. Heads I get tail, Tails I get head.
