Alright next weekend im doin my rear end swap that has 3.42s and also im changin my shocks to kyb's and finally installin front and rear 1LE sways...i wanna change my rear springs also since im back there...will the 1le springs work fine back there or will they raise up my back end?
1LE springs
1LE springs
87 Firebird RIP
96 Camaro RS RIP
94 Patriot Red 1LE Z28 - Sold
02 WS6 TA - SoldTags: None
Re: 1LE springs
1LE shocks? do you mean 1LE springs? if that's what you mean they raised my rear end a bit, raised my front end a little too, I think i wound up with 1 inch up from stock when I put 1LE springs all the way around.-Brad
2000 V-Star Custom 1100
:rock:
Re: 1LE springs
Originally posted by black98V61LE shocks? do you mean 1LE springs? if that's what you mean they raised my rear end a bit, raised my front end a little too, I think i wound up with 1 inch up from stock when I put 1LE springs all the way around.
Re: 1LE springs
Originally posted by SilverRS96the rear springs r 130-170 lbs that r progressive and the rear for ours and reg v8's r only 114 lbs...so thats y i had to ask...
Suspension is all about balance and those changes would unbalance the car in a bad way.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
