Can you stack spacers? I found rims I like, but they have an offset of 0, and I need 45 I believe to fit my Camaro. But, I can only find 15, 20, and 25 spacers. Could I stack two of them to get the right spacing?
Spacers
Re: Spacers
I wouldn't if I were you. Sounds like it would be too much of a load on the lug studs. Not only that, but you may not get too much thread left on the studs with stacked spacers. Either one is unsafe at any speed!
jmosigpic
Re: Spacers
Originally posted by RadRacerOK. So anyone know of any place that sells 45mm or more spacers for our cars?1997 Camaro v6 3.8 <br />Bone Stock, just a little slower then most station wagons.<br />**Either the slowest SS or the prettiest v6**
Re: Spacers
Rim Material: Alloy
Rim Width:8J
Tire Width:245
Rim Diameter (inches):17
Aspect Ratio:45
Offset:0
Number of Bolts:5
Bolt Pattern:5 x 4.75 or 5 x 120.65
They're made for the 3rd gen camaros. And no, I didn't see your post, sorry.~97 3.8L V6 Camaro~
A few things
Only Member of Team Hooker?!?
Re: Spacers
Originally posted by RadRacerRim Material: Alloy
Rim Width:8J
Tire Width:245
Aspect Ratio:45
Offset:0
Number of Bolts:5
http://www.1010tires.com/WheelOffsetCalculator.asp
You can put in the specs of your current wheel and this wheel and it will tell you what kind of difference there is between the two. I thought the 16x8 stock wheels were around 55mm offset so those wheels would stick out a little over 2" farther then stock wheels. If you put a 45mm spacer on it then the wheels would stick out just under 4".1997 Camaro v6 3.8 <br />Bone Stock, just a little slower then most station wagons.<br />**Either the slowest SS or the prettiest v6**
