Hi all...I was checking out Loochys page about the rear disc brake swap...in one of the pics he had a diagram showing a shim for the axle shaft. When I go to GM Parts Direct and look up the part number listed in the diagram, it tells me that they have no record of it. The diagram shows the axle shaft shim part number as #26034667.....anyone have an idea as to what the new/superceded number is? Yeah, I know that I could go to my local Pontiac dealer and ask, but they aren't the brightest bunch on the face of the earth. Thanks in advance for the help.
Need updated part # for disc brake swap
Re: Need updated part # for disc brake swap
12471185 he said this in one of the paragraphs that is the new part #, there good to have just in case , when I did mine I really didn't need them I just grinded down something , which I forget since I did this before my stroke and I only remember some stuff. But just measure to see if you need them or not. There not expensive but good to have if you need them.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms541112471185 he said this in one of the paragraphs that is the new part #, there good to have just in case , when I did mine I really didn't need them I just grinded down something , which I forget since I did this before my stroke and I only remember some stuff. But just measure to see if you need them or not. There not expensive but good to have if you need them.
btw, thanks. I found the shims on gmpartsdirect.
Originally posted by SpeedingFirebirdI am not 100% clear on where to the measure. From the inside of the mounting plate to where?
http://loochy88.cz28.comRobert - owner www.FirebirdV6.com/CamaroV6.com
Raven
larry i sell parts for a living, 228 596 1433. i know the 800 no. to gm i can answer these kinda questions all day96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Hey David...you know I would've called ya on it bro...but I think when I originally posted that, it was before I had actually met ya. lol. I've since found the shims needed. I'll be callin when I need something else though, it never hurts to have connections in the business. :) Thanks Man!!!
i never even used mine... and i have the old set for sale if anyone needs them. (turns out i should have used them, but i didnt want to pull the axles again so i fixed the problem with a set of washers of the same thickness and some grinding on the inside of the calipers)Last edited by Loochy88; 08-19-2007, 09:31 PM.
