A few tire and rim questions! - FirebirdV6.com/CamaroV6.com Message Board
  • A few tire and rim questions!
    Hey All,
    I am looking at some new C6 rims and I know that I want to go with 17 inch rims but there are a few questions I still have:
    #1) Would you suggest 8.5 or 9.5 for the width?
    #2) I am looking at Eagle F1 GS-D3 tires to wrap them in, anyone have these or know anything about their performance? Everyone on the website seems to like them, but I want to check with people who may or may not be paid by goodyear :)
    #3) And finally, what are some of the cheaper places to get tire/wheels?
    Thanks for everything!
    1997 30th Anniversary Camaro.
    SLP CAI, Dynomax, PCM tune, SS Hood, Clear Corners, T-Tops, Sony Xplod
    TEAM RED
    Re: A few tire and rim questions!
    For cheap place to get tires, I'd recommend Tirerack.com
    Sorry I can't give you any advice on your other questions.
    Originally posted by kala
    TEAM BLACK!!!
    parting her out
      i got some C5's off ebay w/ sumitomo tires for $300
      I like mine, there 17x8.5 fronts and 18x9.5 rears, and I noticed a big improvement with traction with the 9.5 rears
      i'd say get 9.5's
      1999 Camaro Z/28
      1973 Firebird Formula
        are the stock wheels 8.5?
        TEAM RED
          stock is 16x8 .
          1997 Camaro LS1 RS
          1994 Camaro - Sold
          1999 Trans am Vert - Sold
          A Few Mods....
            #1) so if I put 9.5s on the rear, would I still be able to do a burnout by powerbraking, or is the tire to wide at that point?
            #2) If I put 9.5s all the way around am I going to have to do anything special to the alignment to make them fit right?
            #3) Can I put 8.5s on the front and 9.5s on the rear, would that work? and am I going to have to do anything special to make thoes work?
            -I dont want the tires to stick out of the fender wells to much, will have 9.5s on it make that happen?
            Sorry about all of the questions I just want to make sure that I make a wise decision about all of this.
            TEAM RED
              You should still be able to do a burn out. If I can, you can (of course, i still have an open differential....)
              If the offset is wrong then it'll stick out. But i don't know much about any of that. I just went to centerline.com and they made the offset for the rear diff than the offset for the front so they'd fit properly in the fenderwell.
                with the C5's I still burnout but I can get up and go a lot better, and they fit fine and dont stick out
                nothing was needed for the rims in my case, when I installed them with the axle jacked up, the tires rubbed against in the rear but once there on I have no rubbing (so in theory if I got the car airbourne they would rub but under no driving instances have they rubbed bumps, etc...)
                1999 Camaro Z/28
                  1. Yes
                  2. No
                  3. Yes you can put 8.5 front and 9.5 rear with no probelms but I suggest running the same size tires/wheels so you can rotate them. Go with 9.5 all around and 275/40 and your money.
                    the 17" fronts 18" rears look a lot better tho
                    1999 Camaro Z/28
                      which offset can you have whit the 9,5 rims under camaro 1998-2000 in 18 inch,because i want buy rims in 18 x9,5 whit 265-40-18 tires on the rear is offset 40 enough for clearence in the rear fenders? stock is 10 offset i believe whit 16-8,0 rims/tyres 215-60-16
