i of picked up a 01 trans am rear today that has all the brake lines on it and the backing plates, rotors and calipers, is there anythin else involved in swapping the brakes over like a proportioning valve or is what i am getting with this rear everything i need, thanx
quick question about swapping from drums to discs
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG'sTags: None
Re: quick question about swapping from drums to discs
from what i remember reading both here and other boards...judging by your nic, you have a 94 3.4??? youll be better off getting a rearend from a 93-97 Fbody...the 98+ had a different ABS set up and the rear discs were larger. seems like the 93-97's had one abs sensor in the top of the gear housing and the 98-02's had the sensors on the backing plates and had ?? 4 ?? wires instead of 3. Im sure someone else can fill ya in on the particulars.
is there anyway to convert my abs set up to accept the newer style, im sure someone out there has done it or knows of someone that has, besides swapping the abs controller from a newer car, i already have the rear end i will sell it if i have to but i dont want to if its at all avoidableLast edited by ninety4three4; 01-17-2007, 03:08 AM.
i swapped to the same style, not the newer style, but i only had calipers, plates, rotors, and ebrake cables. (possibly some shims too... see my write up in that section)
ok so i got the rear tonight and it has a sensor on each backing plate and it has a four wire/prong connector comming off of it, now what is involved in chaning my existing abs wiring to work with this new rearend???
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
