i just bought a 3.42 posi rear out of an 01 trans am, it is equipped with disc brakes, the question i have is the existing drum brake rear in my car only has the one rubber hose that jumps the gap between the body and the rear, the new rear has two hoses that send pressure to an individual caliper, how can i convert the setup on my car to match the new rear, i dont want to rig it cause it is the brakes we are talking about, is it a matter of a Y block at the end of the steel line on the car or is there something else, thanx for the help!!!
question about brake setup on new rearend?
Re: question about brake setup on new rearend?
no one has ever done this, im trying to keep it as factory as possible since i figured it will be most fuctional this way?
76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
You sure its not one of the rears with traction control or something. I got a rear out of 98 and its setup for the discs was the same as with my drum brakes. Individual lines from the brakes come to a T-junction where it then goes to the rest of the cars braking system.1997 Camaro v6 3.8 <br />Bone Stock, just a little slower then most station wagons.<br />**Either the slowest SS or the prettiest v6**
I'm almost positive that the two hoses are a line in and return hose. You will be able to either eliminate one of the hoses or just connect a Y-fitting to your current hose and have it connect up to both of the hoses.
Originally posted by ninety4three4i just bought a 3.42 posi rear out of an 01 trans am, it is equipped with disc brakes, the question i have is the existing drum brake rear in my car only has the one rubber hose that jumps the gap between the body and the rear, the new rear has two hoses that send pressure to an individual caliper, how can i convert the setup on my car to match the new rear, i dont want to rig it cause it is the brakes we are talking about, is it a matter of a Y block at the end of the steel line on the car or is there something else, thanx for the help!!!
You have a traction control rear. Not good. Your ABS is different.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
