I have a 2000 V6 Camaro and as I accelerate my wheels feel as though there grinding, could this be the wheel or the brakes?
Grinding?
Re: Grinding?
if it only occurs while accelerating then uhh ohh
otherwise I would only think it were the brakes2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
Re: Grinding?
sounds like the calipers aren't releasing and it's causing the brake pads to stick on the rotors. Take your wheels off and check your brake pads for grooves or gouges from the brake pads.
For a quick fix if it is the calipers (meaning you don't have the money right now) you can get by with changing your brake pads(but if it is the calipers, these pads will be worn in less than 2 months) until you have the money to replace the real problem.
