OK my car veers quickly to the left as soon as i let go of the steering wheel, it even hurts my arm cuz i gotta force myself to hold the steering wheel more to the right so it wont turn. wut u think, alignment, or i have very low left front tire, both are bald and need to be replaced, idk if tht could e it tho. any suggestions
need alignment!!??
Re: need alignment!!??
tie rod bent?
have you ran into a curb?
That "Suspension" section is over thur:
http://forum.camarov6.com/forumdisplay.php?f=102k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
It could have a lot to do with the tires being bald, but if it does it rather quickly and you need to force the wheel to keep it straight, I would almost have to say you need a front end alignment. That or your tires are way off balance. You need to replace your tires ASAP before it becomes anymore dangerous for you to ride on them and then go from there.
something in the front or rear could be bent or out of alignment or even something like a dragging brake on the left or bad bearings on the left causing drag
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...3 days ago
