need alignment!!?? - FirebirdV6.com/CamaroV6.com Message Board
need alignment!!??
  • need alignment!!??
    OK my car veers quickly to the left as soon as i let go of the steering wheel, it even hurts my arm cuz i gotta force myself to hold the steering wheel more to the right so it wont turn. wut u think, alignment, or i have very low left front tire, both are bald and need to be replaced, idk if tht could e it tho. any suggestions
    Re: need alignment!!??
    tie rod bent?
    have you ran into a curb?
    That "Suspension" section is over thur:
    http://forum.camarov6.com/forumdisplay.php?f=10
      you dont know how to check your tire pressure?
        It could have a lot to do with the tires being bald, but if it does it rather quickly and you need to force the wheel to keep it straight, I would almost have to say you need a front end alignment. That or your tires are way off balance. You need to replace your tires ASAP before it becomes anymore dangerous for you to ride on them and then go from there.
          something in the front or rear could be bent or out of alignment or even something like a dragging brake on the left or bad bearings on the left causing drag
          2000 3.8 A4 Pewter Camaro
            could be a control arm? I smacked a curb 30 mph or so, and it doesn't even do that. lol!
