Does anyone know for sure? Will 2002 WS6 Trans Am wheels (17x9) fit a base model 1995 firebird v6? Will they rub the inner fenders?
WS6 Trans Am wheels fit 1995 Firebird v6?
Re: WS6 Trans Am wheels fit 1995 Firebird v6?
Any 93-95 V6 with the drum rear and fitting 96+ stock wheels will need to file down the hub centering ring to get the wheel on the rear. Not a big deal really, only takes a few minutes per wheel.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
Originally posted by FunkZAny 93-95 V6 with the drum rear and fitting 96+ stock wheels will need to file down the hub centering ring to get the wheel on the rear. Not a big deal really, only takes a few minutes per wheel.
The interference issue is valid for any wheel BUT the WS6. They are Speedline wheels. I have them and have no issues. My GM chrome 5-spoke however did have a problem.
The rear axle is different between 93-97 and 98+ cars.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Is that true also for non-Speedline WS6 wheels?
I had the problem fitting 16" 97 Camaro wheels on my 94. From my understanding it was something that GM changed in 96 (possibly coinciding with Y87?) that made the difference.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
jump on those ws6 speedline wheels if you can.
Originally posted by Predator Birdi have the speedline ws6 wheels on my car and they fit just fine.
by ssms5411Not much going on, replaced my Kenwood double din stereo with a Pioneer double din, the Kenwood had problems. Then replaced my power inverter for my reverse...4 weeks ago
