I know that shocks from my '01 SS will fit on my '96 v6 car but does anyone know if the ride quality will be any good? I'm not sure how much different the spring rate is between an SS and a V6 car and how the shocks are matched up to the spring rate. Has anyone tried this? I'm getting new shocks for the SS and want to use the stock ones i'm taking off of it on my v6 car.
Anyone put stock SS shocks on V6 car?
Re: Anyone put stock SS shocks on V6 car?
are they bilsteins? if not then I'd say it's not worth the trouble-Brad
2000 V-Star Custom 1100
:rock:
GM Stock F-body Springs
FRONT
22077189 (39 N/mm, 223 lbs/in) (93-97 V6)
22133438 (45 N/mm, 257 lbs/in) (98-00 V6)
22077197 (51 N/mm, 292 lbs/in) (93-00 V8)
22132887 (63 N/mm, 360 lb/in) (WS6, 1LE)
REAR
22077418 (16.9 N/mm, 95.4 lbs/in) (93-97 V6)
22077421 (19.9 N/mm, 114 lbs/in) (93-00 V8, 98-00 V6)
22132889 (23 to 30 N/mm, 130-170 lbs/in) (WS6, 1LE)
GM Stock F-body Shocks
FRONT
22151319 (93-97 V6)
22182495 (98-01 V6)
22171227 (1LE DeCarbon)
22140240 (1LE Koni)
22140189 (93-97 V8)
22182498 (98-01 V8)
REAR
22182505 (93-00 V6/V8)
10443949 (01 V6/V8)
22166714 (WS6)
22182505 (1LE DeCarbon)
22140228 (1LE Koni)
People do use V8 take-offs on V6 cars. Depending on how worn your SS shocks are there may or may not be an improvement in ride quality.
My SS does not have Bilstiens, just the DeCarbons. But they only have 36K miles on them. I want to use them to replace my worn out (original 137K mile) shocks on my '96 V6.
So you think they will work out OK and improve ride quality or would it stiffen up the ride too much?01 Camaro SS M6 - SOM<br />- - -<br />96 Camaro V6 daily driver - Dark Purple Metallic<br />- - -<br />\'70 Chevelle SS454 - Fathom Blue, White Stripes
It won't stiffen it up too much. The re-valved DeCarbons that were used on some years for the SS were an improvement over stock so I'd recomend putting them on if they are just sitting around, otherwise I would say builstiens are a better option.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
