so i changed my brakes today and wen i took the car out to brake them in i noticed one of the brakes was sticking bad so i got home checked them out and the front passanger side caliper seems to be frozen about half way u can tell just by looking at it...any idea what to do aside from replacing the whole caliper
frozen caliper...need help
Re: frozen caliper...need help
do you really mean frozen? as in ice?
or locked up?2k2 camaro, K&N, SLP whisper lid, Konis, AEM, HP Tuners, Angel eyes/Halos, CF SS ram air hood, 4.10s, Zexel Torsen, UMI SFCs, CrossFire, BFGs, Gatorback, Catco, Flows, and TLC! DONT feed the Trolls!
i changed my brakes one day and my front passenger one was grabbing at a specific spot each time the rotor came around, so i took it to a couple of places and they said it had frozen somehow and would need to be replaced. i took it back to my house and took the brakes apart again and pushed the pistons in with a C-clamp and reinstalled everything, works fine now. I don't know what was wrong initially, just try to do that and see what happens; it would be kind of expensive to replace a whole caliper, probably at least 100 by the end of it all
try taking it apart and cleaning the bore of dirt and rust. lube up and re assemble. read your repair manual to do it.
wut is the bore? sorry i dont know all these terms! i took it all apart today...took the rotor off and the pads out and sprayed some wd40 around the sides of the pistons and it worked good for about 2 minutes then the same...
like i said, read your repair manual. brake caliper overhaul. self education is the best education.
