Sway bar end link broke! - FirebirdV6.com/CamaroV6.com Message Board
  • Sway bar end link broke!
    I was underneath my car doin some work, when I noticed that the sway bar on the driver side of my car was in the air....but with no bolt supporting it. I also found of of the nuts and bushings nestled inside of my lower control arm.
    I've been driving on like this for a while I guess (this explains why my car has been pulling)
    How do I replace my end links? I need a new end link with all of the nuts and bushings, since mine are long gone. I believe I originally broke them because of rust.
    --<b>David</b>--<br /><a href=\"http://bryant2.bryant.edu/~dsantore/index.htm\" target=\"_blank\">The <b>NEW</b> V6Bird Website!</a> <br /><a href=\"http://members.cardomain.com/thev6bird\" target=\"_blank\">Cardomain site</a><br />ΔX
    Re: Sway bar end link broke!
    You should be able to pick up a kit at your local auto parts store that has everything you need. Should be fairly cheap and install fast.
    Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
      I suggest upgrade to poly ones and stronger bolts... I have broken them on both of my 4th gens...
      they are like $20 for a pair of prothane ones I believe from autozone....
        What he said :tup:
        FirebirdV6.com/CamaroV6.com Administrator
        Stupid is rewarded with the ban button.
        Official Avatar Nazi according to Meatyshells :D
          Another vote for aftermarket. Stockers are cheap bolts that rust through pretty easily.
          Best way to install is with wheels on ramps. Use a torque wrench to make sure the sides are tightened evenly.
          2001 Pewter Firebird Y87, M5
          Go Sabres!
            What size are the rear sway bar endlinks?
            EDIT* Nevermind, FirebirdGT got the sizes for me :)
            1997 Camaro RS A4
            2006 Chevy Colorado
            2003 Kawasaki Ninja ZX6-R
