I will be doing a PA racing k member and lower a arms in about 2 weeks, from what I have read is:
Jack up vehicle, take off tires
support engine with jack & block of wood on oil pan
remove lower shock bolts with the lower ball joint nut.
remove 2 bolts in front for the power steering
remove sway bar bolts
remove the bolts for the motor mounts 2 per side
remove 2 more bolts per side then the k member with the arms should come down, will have a jack under it of course.
Install will be reverse
Zip tie up the power steering lines and brake lines & misc.
Then allignment.
Did I miss anything let me know?
Then allignment.
