brake upgrade - FirebirdV6.com/CamaroV6.com Message Board
brake upgrade
  • brake upgrade
    Ok, so I am doing the brake upgrade. I've already asked if LS1 fronts will work with LT1 rears, the answer is yes. I know this, but here's my question:
    I've heard from a few different sources that it's a bad idea to use the LS1 rear brakes on a 93-97 drum brake car if you're doing the swap. Why?
    Hopefully someone will know.
    Thank you all for your knowledge.
    Travis S.
    1995 Firebird 3.4 V6 M5<br />-Firehawk 17x9 w/275/40/ZR17, flowmaster 80s, high-flow cat<br />*new* BMR lowering springs, Bilstein shocks, WS.6 sway bars, polyurethane bushings.
    Re: brake upgrade
    I remember hearing that there was an extra line or something that went to some part of the newer LS1 rear end that the 93-97 cars weren't equipped with, causing more work than what's worth to get it all working right. You might try a search, I know the differences has been discussed at least lightly, but I don't remember what it was that's different.
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: brake upgrade
      u do know that most of the brakin power is done with the brakes up front right? if ur interested in swappin brakes get the ls1 brakes for the front and stay with lt1 discs for the rear
      87 Firebird RIP
      96 Camaro RS RIP
      94 Patriot Red 1LE Z28 - Sold
      02 WS6 TA - Sold
        Re: brake upgrade
        yes i do, that's what i'm going to do, but i just would like to figure out exactly why people don't swap the rear LS1 brakes...just curious.
          Re: brake upgrade
          It's more work than it's worth. LS1's employ more electronics than the LT1 rear brakes ever did. When I swapped out the drum rear end for the LT1 version, it was just R&R. Nothing more added with the year I pulled it from, it was OBD1. OBD2 adds lots of traction control, bla bla bla stuff. Fact is, LS1 brakes up front with LT1 out back with good pads will stop your car faster than you ever thought possible. Remember, your not carrying as much weight as the V8 guys.
          FirebirdV6.com/CamaroV6.com Administrator
          Stupid is rewarded with the ban button.
          Official Avatar Nazi according to Meatyshells :D
            Re: brake upgrade
            Not worth it.
            Front 93-97 10.5 single-pistion
            98+ 11.9 dual-piston
            Rear 93-97 11.4 single-piston direct action e-brake
            98+ 12.0 single piston drum e-brake
            Raven
              Re: brake upgrade
              thanks for the info guys!
              bought the rear LT1 brakes last night along with a 98+ console
              i'm going to be getting the front LS1s sometime next week.
              and the build begins!!!
                Re: brake upgrade
                Actually the v6 fbody weighs about 100 lbs more than the v8 ! So I guess its worth having on the v6 more than the v8.
                  Re: brake upgrade
                  Actually the v6 fbody weighs about 100 lbs more than the v8 ! So I guess its worth having on the v6 more than the v8. You could always put 2000+ v6 brakes on it, its a nice setup.
