60K V8 takeoff front shocks better than 200k stock shocks? - FirebirdV6.com/CamaroV6.com Message Board
  • 60K V8 takeoff front shocks better than 200k stock shocks?
    i was abke to find a set of stock front shocks off a 99 z with 60k on them for 25 bucks and i am thinking of replacing my stock 200k de carbons, this is all i can afford right now, i am putting eibach pro kit springs in the car and i want to know if this will work until i have the dough for a set of decent shocks to match my springs, basically will ride and handling quality e compromised severly and will the front sit higher like a lowrider ?
    76 Camaro Rally Sport-355/TH350- Soon to be LT1/TH350 with a little laughing gas to wake it up...;)
    89 Ram D350 CTD/M5- 1 Ton Dually getting 27 MPG's
    Re: 60K V8 takeoff front shocks better than 200k stock shocks?
    Dude, if you're gonna be cheap, don't be cheap on shocks... i mean, unless you want to have to replace them all the time. Just buy some nice bilsteins.. they're not that much.
    Originally posted by SSMOWS6
    i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
    R.I.P. '07 Pats
    Still... 18-1 > 1 and done
      i make 75 dollars a week and im in college and im also trying to get it running i know i need good shocks later when i can afford it, so will this work for a few months or no? 25 shipped is alot cheaper than 400 for new shocks
        the shocks are the same on a six as they are a V8 on the front, the spring is what makes the difference so it will not sit higher unless you use the spring too.
          I wouldn't put 60k mile camaro shocks in as a replacement for 200k mile shocks, especially if you are going to be replacing the stock springs with Eibach Pro-Kits. Either just replace the shocks with new low cost replacements, or save up and do Eibach/new performance shock replacement at the same time. Don't put 60k mile Camaro shocks on; they are not great to begin with - at 60k miles they are ready for replacement.
          KYB AGX front and KYB GR2 rear would be a quality relatively inexpensive setup (around $220.)
          <a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
            you can find a full set of z28 takeoff shocks with virtually no miles for about 75 bucks if you look.
            for instance... half a set right here:
            http://cgi.ebay.com/ebaymotors/1993-...85010623QQrdZ1
            Visit My F-Body Page
              Fair enough, but your priorities should be: Good shocks > lowering springs.
              R.I.P. '07 Pats
                well i guess i will do the KYB shocks up front when i put the springs in and i will do the rears when funds allow the springs can wait a while but need the car out of the garage by the 19th of march and its still got the SES light, no front end, exhaust and rear, god i hate being poor :(
                  Its very wise to do it all at once and match them right the first time. Save your $ and do it right. It really depends on what your goals are with the car. KYB shocks are not worth it in my opinion.
                  Bilisten shocks are rated only for stock springs, not anything else. WHen you change the spring rate, you are changing everything. The only way to match it is A)Koni SA or DA shocks or B)Have Sam Strano re-valve a set of bilistens to match your car.
                  Suspenion is just like building a engine, it must be matched not only for performance but for safety as well.
                  1999 Pontiac Trans Am M6 Far from stock.....
                    dont waste any money, put that 25 bucks in a jar and install the springs, if you save long enough, by the time your shocks bite the dust you should have enough for aftermarkets
                    Mystic Teal Metallic
                      Concur. If I were still in college thats how i'D do it. Wait til they are toast.
                      Shocks before lowering spring is more good advice. The springs just add more reqs and complicate things, for little visual gain on an F-bady, IMHO.
                        Broke or not, it's just not worth the effort replacing worn out shocks with other worn out shocks.
                        2001 Pewter Firebird Y87, M5
                        Go Sabres!
                        • 187shark
                          by 187shark
