well i was just wondering what is a good front swaybar for me and how big should i go? i have no suspension mods so what do u guys think? thanks
whats a good swaybar for me
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
Re: whats a good swaybar for me
the only reason i ask is cuse i got a friend thats going to sell me one its a OEM 30MM FRONT SWAY BAR THAT CAME OFF OF his 2000 LS1 TRANS AM.2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
From what I've learned over reading numerous topics here, if you have a stock setup on the rest of the suspension, then stay with the stock swaybars. It's dangerous to upgrade one piece and leave the rest alone.
I went with a larger 32mm front swaybar, but I'm upgrading to V8 springs, bilstein's, better bushings, and all new balljoints & tie rods this springtime. My rear swaybar is 19mm. It came with the V8 disk rear I bought, so I never changed it back to the stock size.
V6bob has some very controversial topics here (as do I)...to say the least, but he has very good reading material when it comes to suspension know-how. I try to read up on his topics when they aren't being spoken from the other end of his anatomy...no pun intended bob :)Last edited by hockeyman; 03-02-2007, 12:51 AM.sigpic
well 30 is def. bigger than what you have now. i have a 32mm from a ls1 and i love it. but i have upgraded other areas of the suspension too, like hockeyman was saying. what is the guys price for the bar? its not a bad idea if you think about upgrading other suspension stuff later on, otherwise.. i would say leave it alone.Dave:
00 Supercharged Camaro - RIP
97 Turbo Camaro - Sold
well he had two of them one oem 30mm OFF OF his 2000 LS1 TRANS AM and the other one is a oem 32mm 1le hallow i went the deal to find out mine and i have 28mm in the front and 21mm in the back so what do u guys think the 30mm or the 32mm thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
If you plan on new springs/shocks you could probably get away with the 32mm. I would wait to put it on though until you do anything else to your suspension. Many v8 guys buy 35mm fronts and sell their stock ones so if you pass up this deal, you'll most likely still find one for a decent price on ebay in the future.
Originally posted by Kal-Elwell he had two of them one oem 30mm OFF OF his 2000 LS1 TRANS AM and the other one is a oem 32mm 1le hallow i went the deal to find out mine and i have 28mm in the front and 21mm in the back so what do u guys think the 30mm or the 32mm thanks
A rear 21mm needs at least a 32mm front, if not a 35mm!Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Originally posted by SSMOWS6i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
Still... 18-1 > 1 and done
thats what dealer said he looked it up with my vin nimber ill ask again but im sure he said 28mm front 21mm in the back2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Originally posted by Kal-Elthats what dealer said he looked it up with my vin nimber ill ask again but im sure he said 28mm front 21mm in the back
If you have factory sway bars, you have 28/15 if 98+ V6, or 30/17 if 93-97 V6.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
well i have a 2000 so i got a 28/15 then right if so is it cool if i get a 30mm off of a 2001 ls1 trans am2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
Yes. I think its fairly universially agreed upon that a bigger front sway bar is better.... ... maybe
(is it me or is there really no correct answer to the question: What sway bar should i get? ... Kind of annoying)
Originally posted by TheGr8SchlotzkyWhy did they switch to smaller sway bars in the later years? I thought bigger was better (to an extent and properly matched)
Remember, the suspension is a SYSTEM - shocks, springs, sway bars, even tires, all working together.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
cool then i will get the 30mm swaybar then :) thanks guys for helping me with this and i know it is kinda annoying :)Last edited by Kal-El; 03-05-2007, 06:42 PM.2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
