tt2 rubbing on caliper - FirebirdV6.com/CamaroV6.com Message Board
  • tt2 rubbing on caliper
    So i got some TT2s and the front are rubbin on the caliper bracket, what would be the best solution... a spacer or griding off some of the rotor. Also why would this happen... cause its only the driver side front
    Re: tt2 rubbing on caliper
    can you be more specific on what wheel/tire combo,stock or modified suspension,what year of car
    never heard of grinding off rotor to help with clearance problems on calipers.
      i had the same problem, they ended up just grinding the caliper down a little to help with clearance :)
        umm...Why would you grind the caliper when you could just get a spacer?
        1998 Camaro V6 \"Black Mamba\"<br />Y87<br />Whisper Lid w/ K&N filter<br />Flowmaster American Thunder<br />Numerous appearance mods.<br /> <a href=\"http://www.cardomain.com/ride/2154172\" target=\"_blank\">Car Domain</a>
          i ended up grinding the caliper down a lil bit... nothin major but i didnt want to run a spacer because then the one wheel would be kicked out farther and then the spacer woulda rubbed and i woulda heard it grinding
