I'm in the market for a new set of tires and want to go wider, at least for the rear. Going from stock to P255/50/R16, BF Goodrich G-Force, on a 2002 Firebird. I would like to know if I should use the same size all the way around, or keep narrower tires in front. I've heard that with wide tires in front, you lose some control on wet roads (displace more water) but gain corner handeling. Kind of a trade-off I suppose.
tire size - front vs. rear...
Re: tire size - front vs. rear...
Originally posted by dafirebirdI'm in the market for a new set of tires and want to go wider, at least for the rear. Going from stock to P255/50/R16, BF Goodrich G-Force, on a 2002 Firebird. I would like to know if I should use the same size all the way around, or keep narrower tires in front. I've heard that with wide tires in front, you lose some control on wet roads (displace more water) but gain corner handeling. Kind of a trade-off I suppose.
Going from a 235 or 245 to a 255 won't affect your wet traction nearly as much as changing the actual tire tread. So if you buy some good wet/dry tires then you shouldn't have to worry about it. All you might want to think about is that having a wider tire up front will make steering at lower speeds harder.
Originally posted by SSMOWS6i mean, you can always fly wes out there and since he's a tool sometimes, fashion him into a plow for the maro
Still... 18-1 > 1 and done
245/50-16 is a good size for the 4th gen Fbody. I have 275/40-17 all around (Nitto NT-555 RII DOT R tires) on 17x9.5 wheels and grip is much better than stock, even in the wet. Don't want to run through water puddles with them but it grips great in the wet. The power steering pump failed after I came off a track session last year.... the aluminum framed sparco steering wheel was on the verge of distorting with the ammount of force required to turn it with a failed pump (was a long drive home!)
Main thing is to get a GOOD tire in the right size... choosing a poor tire will be nothing but frustrating to your cars performance. 255/50-16 are oversized tires...<a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
Originally posted by Vracer111245/50-16 is a good size for the 4th gen Fbody. I have 275/40-17 all around (Nitto NT-555 RII DOT R tires) on 17x9.5 wheels and grip is much better than stock, even in the wet. Don't want to run through water puddles with them but it grips great in the wet. The power steering pump failed after I came off a track session last year.... the aluminum framed sparco steering wheel was on the verge of distorting with the ammount of force required to turn it with a failed pump (was a long drive home!)
Let me just say this for wet driving: Having a narrow tire is not nessesarily an advantage, driving in rain ain't like snow. Its the ability of the tire to get as much water out from under it as possible that matters more than its width. What you need is a tire that has large channels in it that allow the water to leave the tire surface. A test done by Tirerack and Car and Driver magazine concluded that out of all the "high performance" tires on the market today this tire: http://www.tirerack.com/tires/tires....Eagle+F1+GS-D3
was the most effective in the wet. You'll notice its got a lot of deep channels that allow water to escape from under the tire. No coincidence there. If you ever need more proof, just look at F1; they've got what? 15" wide tires and can run up to 180mph in wet conditions.
Originally posted by FinkledbodyYes but with a front an rear wing exhurting 60,000lbs +/- of downforce on the wheels... it allows for 180+ MPH in the rain.. put 15" tires on your car an an try doing 50 MPH in the rain.. haha
