i was wondering on my instructions it says to have the vehicle at ride height well i dont think i can fit under there at ride hieght but could i put the car on ramps in sted or is there a nother methed on doing this thanks
question about instaling end links
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainersTags: None
Re: question about instaling end links
I heard putting the front on ramps and the jacking the back up by the rear end even with the ramp so that it would simulate it being at ride hieght. Someone correct me if im wrong.
Also anyone have ramps they recommend from and fbody with gfx?Check out my cardomain site!<br /><a href=\"http://members.cardomain.com/99pewterv6\" target=\"_blank\">My Car</a>
When I installed mine, I jacked up the opposite side of the car so it compressed the suspension of the side I was working on. Then I jacked up the other side and attached the endlink to the other side. I then lowered the car to ride height and turned the wheels out. I was able to get the wrenches on the endlinks to finish tighting. I didn't have a problem with the rears. My driveway was sort of a hill and I was able to fit underneath without jacking the car up.69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
Front on ramps, rear jackstands under the axle tubes.Drivetrain Moderator - "There are no stupid questions, only stupid people!"
2001 Pewter Firebird Y87, M5
Go Sabres!
cool thanks for the help guys i end up going up some thin peices of flate wood and fit underthere it was a pain in the butt but maniged to it2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
