Kyb vs. Bilsteins - FirebirdV6.com/CamaroV6.com Message Board
Kyb vs. Bilsteins
  • Kyb vs. Bilsteins
    which are better? Iwent though most of the posts and no one says which one is better.
    I know blisteins are sweet- more expensive
    Kyb are cheap on ebay, are Kyb's worth it or is it better to get the bilsteins for the long run, for durability and quailty. Im not looking to autox yet. but i do need new shocks and Kyb has a dec deal for springs and shocks for $392 which is very tempting. Even tho im not lookin for springs.
    Can somone please give me a solid answer if the bilsteins are worth the extra $ considering i can get a set of bilsteins for the price of kyb's shock and springs.
    Re: Kyb vs. Bilsteins
    Bilsteins
    Raven
      so go bilsteins or the kyb's with the springs. i could go either way
      i dont need to be lower'd but that is a awesome deal "GR-2 shocks n springs"
        FWIW, it depends on the roads in your area, what your willing to put up with, and your use for the car. If your gonna autox in the future go with the Bilsteins. If only for the street, ride is important, and the roads around stink, go KYB. I put Bilsteins on my 96RS and they are pretty stiff. I like the way the car handles with them but the ride is much worse, which is what I expected going with a high performance shock. They are great shocks, but if you live in a area with bad roads go with the kybs. I've put Kyb gr2 on my 97z24 and now my 2002 grand prix GT. The struts were an improvement over stock, but not as stiff as the Bilsteins. I also put kyb gas a adjust shocks on my 69camaro(won't fit on the 4th gens). They are stiff like the Bilsteins. Haven't tried the agx line yet. Kybs are made in japan and they supply many OEM's with there shocks so they are not a cheapo shock with no quality.
        69 Camaro 350 4spd, Full Hotchkis susp, Baer brakes, moser 12 bolt, Flowmaster<br /><br />96 RS Hotchkis STB, subframe connectors, Hotchkis LCA and adj Panhard rod, SS camaro sway bars, Bilstein shocks, powerslot rotors, Borla exhaust, rksport headers, k@nFIPK
          so gona go with the kyb's but do i need the springs? roads are kinda shatty around. and do you guys have lots of problems with botteming out. are these kyb's GR-2's gas-ajust 8ways?
          :banana:
            You should not need springs as they should last the life of the car.
            GR-2® Premium Shocks and Struts are specially designed to provide a smooth, secure ride with excellent control for drivers who are looking for ride comfort and improved handling. In my opinion these shocks are a little bit of an upgrade over stock, but still have a decent ride.
            93-02 front number model 341356 rear 343211
            Gas-a-Just® High Performance Shocks' higher gas pressure keeps tires glued to the road while its superior strength monotube configuration provides durability and fade-free performance. From my experience these shocks have a much firmer ride similiar to he Bilsteins
            Front KG9310 rear KG5562
            With its competition grade engineering and construction, AGX® Sport Adjustable Shocks and Struts are perfect for sport enthusiasts and high performance drivers.
            Front 741034 Rear 743019
              wait i can also get a set of Kyb's AGX's for like the same price at strano's
              and the AGX's (adjustable) are better then the GR-2 Right.
              wow ebay has no deals anymore
                I got my full set of Bilstiens on ebay for $338 with shipping. Got Eibach 1" lowering springs from Summit for $250. I like the ride and the stance of the car now. The ride is a bit stiffer with the Bilstiens over the factory DeCarbons....but its not so bad that I cant live with it. I know I like the way it goes around corners now.
                  I have the Billstein Hd's all aruond on my car and they feel great. I cnat say much for the KYB's thought Im gettin ready to put some all around on my gf's Grand Am. Now I just need a set of sways to finish off my suspension, lol.
                  01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
                  www.vaperz.com
                    bilsteins all day long!!! i stick to the ground so good with them
                    WAWA-A-HOLIC
