Shocks - FirebirdV6.com/CamaroV6.com Message Board
Shocks
  • Shocks
    Well heres the point I need answered if you have a moment. I have a 99 v6 camaro and im looking to upgrade the shocks for autocross. I was wondering what the difference is going to be between the hd and slp bilsteins. Is it going to be worth the extra $250 to get the slp units. Also should I replace the strut tops on the fronts with the install? I currently have a few mods done and a couple more to go.
    Done:
    FIPK
    Flowmaster Catback
    B&M Shifter
    Aluminum DS
    LSD
    Hotchkis LCA
    Hotchkis Panhard bar
    32mm with poly front bar
    19mm with poly rear bar
    torque arm bushing
    trans bushing
    Next:
    Shocks
    Tires
    SS brake lines
    I have 66k on the car and it probably needs new struts anyway as well as a operformance alignment to set the camber up for the track, so I figured I should just do the struts now. What do you think?
