Shock Quality - FirebirdV6.com/CamaroV6.com Message Board
Shock Quality
  • Shock Quality
    I've got some shocks that i acquired from hockeyman in the FS section, and i was swapping them out for my stock shocks today, but noticed something. ( I don't think my shocks have ever been replaced..if they have, they were with factory replacements) The car has just turned to 121K.
    I just took out one shock, and I was comparing the two by compressing them by hand. The Gabriel Pro Rider shocks had noticably less resistance when compressing than the stock ones, but when stretching out again, the gabriels have noticably more resistance. These new ones have many less miles on them but I'm unsure if they are even going to be any better.
    Spark Notes: Stock shocks have more resistance compressing them, and less resistance expanding again than the new ones. Which ones should I use?
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
    Re: Shock Quality
    I'm sure the new shocks are fine. Different shocks have different compression and reboud properties. Your "test" really proves nothing about the quality of the shocks (unless the gabriel's never come back, then they are toast).
      Re: Shock Quality
      what do you mean by "never come back?"
        Re: Shock Quality
        More than likely to the orignal position.
          Re: Shock Quality
          If you compress the shock and it stays compressed, then it's probably bad. Eventually, withouth load, all shocks should return to their expanded position.
