Quick question my back tires are a little thin right now and I am short on funds.
I currently have 275 40 17 all the way around but found a really good deal on a couple of 275 45 17 will they fit in the back or will I run into problems I have a 98 Camaro if that makes a difference!
If i did my math right, the back tires with the bigger rims, lower sidewalls and wider tires than stock should end up being a total of 13cm wider than what 16 inch stock tires would be so I would say they would fit in the rear but not the front. Hopefully someone else will chime in.
