help please - FirebirdV6.com/CamaroV6.com Message Board
help please
  • help please
    ok so i bought new rims and i put them on. for some reason the back ones are making a wired noise on both side and from some reason it seems that the drums are lose on both side. if i put the old one back on and its fine and the drums are not lose what could this be. the rims are off a 02 tans am so it not like there wrong or anything .
    Re: help please
    Are you sure the rims were on properly? The reason I ask is because the center-hole on the late model rims is slightly smaller that they were on the older ones (pre 98 I believe), so they will not correctly fit onto our cars on the rear.
    You have to grind a small amount out of the center-hole and it will fit just fine.
    Representin' Team Red In The North
    Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
    Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
    Black/Red '02 Honda CBR 954RR Fireblade
      Re: help please
      grind down the rim or the drum and what do i use to grid it with. thats for ur help btw
        Re: help please
        You'll have to dring down the wheel. I used a dremel on mine. Any tool similar to that will work. You dont have to take a whole lot off either.
