ok so i bought new rims and i put them on. for some reason the back ones are making a wired noise on both side and from some reason it seems that the drums are lose on both side. if i put the old one back on and its fine and the drums are not lose what could this be. the rims are off a 02 tans am so it not like there wrong or anything .
help please
Re: help please
Are you sure the rims were on properly? The reason I ask is because the center-hole on the late model rims is slightly smaller that they were on the older ones (pre 98 I believe), so they will not correctly fit onto our cars on the rear.
You have to grind a small amount out of the center-hole and it will fit just fine.Representin' Team Red In The North
Red '96 Pontiac Firebird "Smokeshow" 3800, M5, Far From Stock!!
Black/Red '89 Jeep Cherokee "Tigerclaw" Chev 327, Turbo 400... Stock What??
Black/Red '02 Honda CBR 954RR Fireblade
Re: help please
You'll have to dring down the wheel. I used a dremel on mine. Any tool similar to that will work. You dont have to take a whole lot off either.Representin' Team Red In The North
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
