Abs Inop - FirebirdV6.com/CamaroV6.com Message Board
Abs Inop
  • #16
    Re: Abs Inop
    when i brake, nothing feels odd, response is normal. i just finished cleaning the rear sensor. i turned the car on, and the light still stays on. later this week i will check the front sensors.
    • #17
      Re: Abs Inop
      the sensors in the front are not serviced seperately from the hub asm. that is why they are $300 each side. best thing to do is to let someone look at it to tell which one.
      mine used to come on all the time when it was cold, my low trac light would come on and my brakes would let go ubtil the abs light inop came on. since summer time no problem
      96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
      • #18
        Re: Abs Inop
        alright
        • #19
          Re: Abs Inop
          part no. 7470587-hub,frt whl(less rotor)(w/speed sensor) $393.28 . there is a dealer in porterville, ca that shows to have one in stock. faggart buick pont gmc truck
          • #20
            Re: Abs Inop
            quick question. what kind of rims do you have and what size? i have z06 wheels and i have 18s in back 17s in front and thats why my light is on. but my abs works after i cleaned the sensor. but i still have the light bc of my offset wheels. let me know.
            cant wait till my lt1 and nitrous.
            • #21
              Re: Abs Inop
              stock salads. the one on the rear left is damaged, about 3 inches is missing on the circumfrence. but i am replacing them with a set of chrome stock salads.
              • #22
                Re: Abs Inop
                You Can Get A Whole Set Of Ss Camaro Wheels From Any Gm Dealer For Less Then A Grand. Part No. 12498899 And 12498900
                • #23
                  Re: Abs Inop
                  the only reason i got the chrome salads were that they where flawless, and the tires were close to being new. i got them for 200 of a guy who got 20s for his car -_-'
                  • #24
                    Re: Abs Inop
                    im not bringing this thread back to life just to whore, for all of you that know my lil' story...any how, i just got out of the shower from doing a tranny fluid drain. i know a lot of you prefer a flush, from what iv research. and i aslo decided to upgrade to 9006 silverstars ultra on my 95. anyhow, back to the point while working, and waiting for the fluid to finish dripping, i took a towel and started to clean the bottom of my car. i noticed that on the passangers side, the abs wires where hanging, unlike the drivers side. i inspected them. i saw that the black plastic thing was ripped, and the greenish wire was snapped completely, the yellow wire was only held together by a small yellow part. i ended up peeling the color thing on the wires, hooking them together, taping them up, taped up the black diddly. if you noticed there are like 3 little plastic braces diddlys. the 2 closes to the wheel were un hooked. i was only able to hook the middle one, since the one closest to the tire was broken i couldnt hook that one up. but it seems i wont have a problem. apparently, the wires were rubbing against the tire. result no more light. woot woot Y^.^Y
                    • #25
                      Re: Abs Inop
                      Thats good, I think I figured my problem also, bad abs ring.
                      Originally posted by kala
                      I'll have buttsecks with Richard Simmons!
                      TEAM BLACK!!!
                      parting her out
                      • #26
                        Re: Abs Inop
                        I have a question how to determine that the problem is with abs ring? How it is changed?
                        • #27
                          Re: Abs Inop
                          If you open up the differntial cover and look at the ABS ring it will be worn down and then you'll know. Not sure on replacing it as I replaced the whole rear on mine.
                          TEAM BLACK!!!
                          parting her out
                          • Andy H
                            Transmission removal help!!
                            by Andy H
                          • 2.8 Bird
                            Abs inop
                            by 2.8 Bird
                          • fishin
                            by fishin
