Hey guys I finaly installed my v8 sway bars on Tuesday. It wasnt a real tough job but it did take me a little longer than expected to do it. It was the first time I messed with something like that and it came out just fine. The only problem I had was on the front drivers side bushing I couldnt get one of te bolts in becacust the hole woudlnt line up. I tried beating it with a hammer to get the bushing and bracket to move to help line the holes up but that didnt work. So the next morning I took the car to my buddy who is a mechanic and it took him like 3 minutes to fix it. He had a bigger hammer and air tools which I didnt have, lol. So its all good now. I have the 32m/19m setup with energy suspension bushings. I will be puting on my Hotckis 1in drop springs next week to complete my suspension. As it sets now the car feels great around curves cuz it dont lean as much and just hugs them. It feels like I float around them now compared to before on the stock v6 bars. I like it overall, great upgrade.
Installed the sway bars!!!
01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Tags: None
Re: Installed the sway bars!!!
Silly question. What is the weight diff between the stock solid one and the hollow 32mm? Or what are their respective weight alone. I'm a weight freak nothing unneccesary added ever.Let's flip a coin. Heads I get tail, Tails I get head.
Yes it's the front bar. The front bar is fine to go large on even with stock shocks and springs though. The rear bar is another story.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
I'm pretty sure Chris (Firehawk N WV) has Bilstein HD's under there. I think he said they were the SLP revalved deals, but I can't remember for sure.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
Yes, they are the revalved SLP shocks. Im not sure on the weigh difference on the bars man, but im sure its no more than 5lbs or so.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Originally posted by rdrr9632mm in front 21mm out back for me... rear end seems a little stiff but she definatley scoots around the turns. what brand did you go with? BMR is what i have!
The 21 is simply too big for the car. The rear bar doesn't prevent roll, it's a tuning device for balance. It places more load on the rear, and thus reduces rear traction. Too big is really bad.
A 21 rear is too big for most all springs. With stock V6 springs I think even a 19 is too big. They're surely not the hot setup.Last edited by V6Bob; 05-05-2007, 04:47 AM.2000 Firebird convert, chameleon/tan, M5, Y87, TCS, BMR tower brace and panhard, KBDD sfcs, 245/50-16 GSCs
the car handles better than i can stay in the seat... also i have never had a problem with spinning out and i have swerved to avoid all sorts of things at some pretty dang high speeds... i think its a great set up. my dad is the one that did the suspension, he knows his stuff about auto xing and thats what he built it for. now that it scoots through the turns im hoping to make it scoot a little faster in a straight line.
Originally posted by rdrr96the car handles better than i can stay in the seat... also i have never had a problem with spinning out and i have swerved to avoid all sorts of things at some pretty dang high speeds... i think its a great set up. my dad is the one that did the suspension, he knows his stuff about auto xing and thats what he built it for. now that it scoots through the turns im hoping to make it scoot a little faster in a straight line.
I have to agree with V6Bob. A 32/21 is not safe on V6 springs. I had it and changed my springs.
So, if your dad did your suspension, what spring rates do you have front and rear?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
no clue as to what the spring rate is... my dad put the suspension together with some Bilstein SS shocks, lowering springs, sway bars, panhard rod, all new poly bushings and LCA's
i dont doubt that V6bob is correct when your using v6 springs but with how the car is set up it handles, like i said before, better than i can stay in the seat.
im not on here to get told whats wrong with my set up. i was just curious as to what size rear sway bar he had.
I wanted BMR origianaly then I realized why pay all that money when they arent realy seen. So I just went with stock v8 bars. I sanded some of the rust off them then repainted them black. I added the red Energy Suspension bushings for better control and a little color. As sadi before Im running the 32/19 setup and I love it so far. I will be puting on my Hotckis springs this week or so to finish out my suspension.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
Originally posted by rdrr96no clue as to what the spring rate is... my dad put the suspension together with some Bilstein SS shocks, lowering springs, sway bars, panhard rod, all new poly bushings and LCA's
im not on here to get told whats wrong with my set up. i was just curious as to what size rear sway bar he had.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
