Suspension mods - FirebirdV6.com/CamaroV6.com Message Board
Suspension mods
  • Suspension mods
    hey guys, well i have some great news i just ordered 4 brand new Bilstein shocks and springs, now i am looking for a better ride out of my car and i know this is a good start. what else would you recomend for the smothest ride? the car is not really being set up for track or drag, my suspension went to **** so i figured to upgrade sence i have to fix it. a little bit of handing upgrade would be nice. but just asking what you think? thanks guys love the site.
    Re: Suspension mods
    http://forum.camarov6.com/showthread.php?t=63700
    Check that link out, it's got some good info and a good place to start.
    Let's flip a coin. Heads I get tail, Tails I get head.
      Re: Suspension mods
      oo ok cool hey thanks there is a lot of info in there. i can't wait untill i get those bad boys on. thanks again. questions are answered.
        Re: Suspension mods
        If you aren't looking for huge changes here are my recommendations. Get some Moog bushings for your stock LCA's (this helps solve the wheel hop problem), an adjustable PHB to recenter the rear since it has been lowered not (rod ends won't affect ride quality here but will require replacement every few years so the spohn adjustable PHB with poly bushings might be better), and to improve handling get some stock sway bars off a WS6/SS (this is a 32mm hollow front bar and a 19mm rear bar which are pretty neutral with stiffer springs which I'm assuming you have). That is a fairly cheap, low maintenance, quality setup for improved handling without killing ride quality.
          Re: Suspension mods
          I don't know but I've said it before and I will say it again... outcornering cars worth alot more than yours is a gooooood feeling :)
            Re: Suspension mods
            My feeling exactly. A properly tuned suspension in an f-body can out handle stock c5 corvettes.
              Re: Suspension mods
              definantly and I was going through the terwilleger curves... really curve freeway toward down town. A wrx sti had more body roll than I figure I was having, sweet. although he would probably smoke me in the straights(never found out) it was a great feeling
