Necessity of doing Alignment after shock installation - FirebirdV6.com/CamaroV6.com Message Board
  • Necessity of doing Alignment after shock installation
    How necessary is it to do alignment after shock installation? I can see the need of doing that (if maybe ) when installing after market shocks (i.e. Bilstein, KYB). But lets say you're changing your shock de-carbons to a brand new set de-carbons (v6 or v8) , do you really need to spend $80(to 100) to do alignment?
    09 Nissan 370Z MB M6 Sports Package
    www.the370z.com
    Re: Necessity of doing Alignment after shock installation
    I didn't but it probably wouldn't hurt. may extend tire life, but I go so fast around corners now that wear on tires is an issue anyways...
      Unless you lower it or mess with the upper or lower a arms. I wouldn't, but if you haven't had a allignment in along time I would just get one , like stated above for tire life.
        I agree. I didn't see that you were going stock to stock.. there should be no reason to check the alignment
          Thanks, that helps.
          www.the370z.com
            hey Im an allignment tech. I agree if you have not checked allignment in awhile do it or if your tires are showing alot of wear.but the camber and caster probably wont be affected by replacing the shocks on our cars
              Thanks bro. I have installed them today. So far, I didn't feel anything. I'll find out tomorrow at highway speed if there's any vibrations or anything. I'll keep posted.
              www.the370z.com
