bagged my powersteering pump - FirebirdV6.com/CamaroV6.com Message Board
  • bagged my powersteering pump
    it was raining and i wanted to do donuts.:cool: i got some nice tight ones to. it whines like a hurting FOR.d a bit, it worked fine when i was doing donuts and then likek 2 minutes later i noticed it going into a parking lot.
    Is it hard to get fixed or is it expensive.
    i'll check it in the morning and maybe to fluid but i think it needs to be rebuilt or replaced, anyone blow there PS pumps doing donuts.
    Re: bagged my powersteering pump
    I haven't...but, if you hold the wheel at lock for that long it's bound to happen....live and learn, dont do it again.
    05' CTS-V
    00' Camaro - SOLD :(
      Yes, $400+ at a dealer
      Raven
        i never turn my wheel more then 1 and half turns, even though it goes alittle bit farther then that, i do it so i dont get to that wineing part and risk messing it up.
        donuts FTW!!
          It works now, but it whines when i turn the wheel and it conked out on me once for like one turn then worked again. can i get them rebuilt or just by a new or used one. or do i just get the system drained idono whats easier.
            I got a used PS pump off ebay for $25 shipped to me. (I blew mine doing donuts too)
            It took less than a half-hour to install, PIECE OF CAKE, and now I have my power steering again :)
            EDIT: Some times you can bleed the system, to remove air, this may work it may not, most likely you'll need a new pump
            1999 Camaro Z/28
            1973 Firebird Formula
              nice i think i saw one on ebay. but it was for a 93-97 lt1 idono if that will work tho> will it? so i can do this on my driveway then. i nthink i can get a used one for $170 from a wreaker,do any onther vehicals have the same pump.
                Dont replace it with another junk stock unit - either get a brand new one or (even better) go with a Turn-one high performance pump that will last longer than the car will.
                TurnOne
                <a href=\"http://www.cardomain.com/id/vracer111\" target=\"_blank\">My \'98 Camaro</a><br /><br /><a href=\"http://www.honda-tech.com/garage?cmd=viewcar&id=1223\" target=\"_blank\">My \'98 Tacoma</a>
                  TurnOne
                  will the ls1 stuff work for us? im asumming it would, but when and if mine goes out, i dont want another stock one.
                    No LS1 is not the same fit. If you call Turn-one or e-mail them they have one for the 3.8L V6's and will work with you. Cost is about $220 for the pump.
                      The only way to go when replacing the PS pump is with a Turn One unit...I just happen to have one new in the box for $250 including shipping..RP
