Has any body here used lakewoods traction action bars?, if so has anybody had any problems with them breaking?
Traction action
Re: Traction action
If you are daily driving the car those would not be a good choice. Also unless you are putting down serious power they won't be needed at all. What are you wanting to do with the car?2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Re: Traction action
Alright. Then my recommendation would be the J&M 3piece poly LCA's from hotpart.com . Since I doubt you will ever need an adjustable LCA these would be great. They offer lower deflection and higher strenth than stock and won't bind like standard poly. Rod Ends can be better but for a street driven car they just wouldn'g last long enough to be a great option.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
