BRAKES? HeLP - FirebirdV6.com/CamaroV6.com Message Board
BRAKES? HeLP
  • BRAKES? HeLP
    Ok, me and my buddy just put on brand new rotors, and ceramic pads on the rear brakes. Now it is rubbing and grinnd more then before!!! I didnt really do any adjusting on the brakes, but i kno he didnt adjust any little screw, or something everyone says is in there idk. But are we missing something, everythings on right, but it rubs like a mofo, will someone send a site or explain the correct way to doing brakes, or what we could have missed. thanks
    Re: BRAKES? HeLP
    take the pins out and greese them up. (pins-you know where the bolts go into.) just pull it and the bolt and rubber boot will come free. get a jar of bearing greese and just drunk it in there. stop at the boot. then stick it back in the caliper. make sure that rubber boot is connected back up.
    WAWA-A-HOLIC
      Re: BRAKES? HeLP
      There is a small hex screw on the rear calipers that needs to be adjusted when new thicker pads are installed. I know a lot of people say the brakes self adjust, but trust me the rears do not. I spent hours trying to turn that stupid little screw because with new pads I couldn't even get the calipers back over the rotors. It almost came down to buying new calipers, but the screw finally broke loose.
        Re: BRAKES? HeLP
        What years are you refering to? 93-97 or 98+ ?
        Raven
          Re: BRAKES? HeLP
          93-97 with 4 wheel disc.
            Re: BRAKES? HeLP
            That sounded so good the way you said that.
            Let's flip a coin. Heads I get tail, Tails I get head.
              Re: BRAKES? HeLP
              Creepy? :stp:
                Re: BRAKES? HeLP
                lmfao. i knew someone would take it that way.
                WAWA-A-HOLIC
                  Re: BRAKES? HeLP
                  I was sitting there at work and I read the original post and then I read yours about greasing up the bolt and putting it in properly and I found myself a little uncomfortable sitting in the office all of a sudden.
                    Re: BRAKES? HeLP
                    NO, DONT USE THIS STUFF!!
                    You should use a proper silicon based extreme high temperature grease! If you use just bearing grease, or common petroleum, soap stone, or lithium based greases, the high temps will cause them to solidify and sieze up the pins, which will prevent the calipers from floating.
                      Re: BRAKES? HeLP
                      Oh god you might just be my life saver... lol... I can't get my rear pads on and it was driving me nuts.. i just need another 1/8th of an inch or hell, even less!
                      I ended up putting the old back pad in just because I ran out of beer and fowl language!!! Thank you god for posting today! lol!
                      I'm t3h n00b!
                        Re: BRAKES? HeLP
                        Only cause you are a good looking girl with a bad *** ride... what more do men want?
