Ok guys i just did my rear brakes, bought new caliper, rotors, and ceramic pads! hey make a constant rubbing sound! i brought it too my dumb mechanic and told me he fixedit, come to pick it up, and sounds still there. Its liek a loud high pitched rubbing sound, and it did it when i was up on the jacks, so it sounds like it definately the brakes. WHat whould cause this to be rubbing, and what can i do to get rid of the noise.
Brake Noise!
Re: Brake Noise!
drive around a little bit and see it they loosen up, pretty much the same thing happen when i redidt my brakes and they loosened up after a day or 2
Re: Brake Noise!
Do they only do it for the first few miles or so or the entire time. Ceramic pads will usually make some noise before they heat up.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
