so if you saw my previous post, you know what i was doing. so the inner tread of my passenger tire is wearing out really fast. iv had these tires for less than 1/2 a year. my previous tires, same problem occured. iv gotten these tire balanced. any idea why it only happens on the wheel?
-izz!
check if there is any grease inside the dust boot, if it is dry then it most likely needs to be replaced, and if so make sure it has a grease fitting so in the future you can regrease if ness.
get the car a new alighnment and see, thats what it sounds like.
does the car go down the road straight if you take your hands off the wheel?
on the highway, where the pavement is fairly new, its it goes pretty straight. the normal roads i drive are really beatup, so if i let go of the wheel, it bounces left and right, but the car usually goes a lilttle to drivers side. when i got the tires balanced, and when i got my front shocks installed, the mechanics said the alignment was a little off, but not enough that it would need work. san jose is full of mechanics, v started to notice most of them are ****ty
i thought of a quick solution...kinda. while i get some $ for the alignment, im going to switch the two front tires, s the otehr good tires starts wearing out, and the beat up one can have a break.... yea..
