tire problems - FirebirdV6.com/CamaroV6.com Message Board
tire problems
  • tire problems
    so if you saw my previous post, you know what i was doing. so the inner tread of my passenger tire is wearing out really fast. iv had these tires for less than 1/2 a year. my previous tires, same problem occured. iv gotten these tire balanced. any idea why it only happens on the wheel?
    -izz!
    Re: tire problems
    check your alignment
    1996 Chevrolet Camaro
    1995 Buick Park Avenue Ultra
    --Appearance Moderator--
      Re: tire problems
      aight
        Re: tire problems
        also check the ball-joint
          Re: tire problems
          what certain details should i look for
            Re: tire problems
            check if there is any grease inside the dust boot, if it is dry then it most likely needs to be replaced, and if so make sure it has a grease fitting so in the future you can regrease if ness.
              Re: tire problems
              thnx for the help guys
                Re: tire problems
                get the car a new alighnment and see, thats what it sounds like.
                does the car go down the road straight if you take your hands off the wheel?
                  Re: tire problems
                  on the highway, where the pavement is fairly new, its it goes pretty straight. the normal roads i drive are really beatup, so if i let go of the wheel, it bounces left and right, but the car usually goes a lilttle to drivers side. when i got the tires balanced, and when i got my front shocks installed, the mechanics said the alignment was a little off, but not enough that it would need work. san jose is full of mechanics, v started to notice most of them are ****ty
                    Re: tire problems
                    i thought of a quick solution...kinda. while i get some $ for the alignment, im going to switch the two front tires, s the otehr good tires starts wearing out, and the beat up one can have a break.... yea..
                      Re: tire problems
                      you should rotate every 10K anyway
                      http://www.cardomain.com/memberpage/799659
                        Re: tire problems
                        iv had them for only 4 or 5 months less than 9k on them *trear* thnx for reminding me Y^.^Y
