Bump Stops - FirebirdV6.com/CamaroV6.com Message Board
Bump Stops
  • Bump Stops
    Where can i get bump stops. Mine are just deteriorated. I went to autozone. They said they didn't carry them. Also NAPA and Advanced Discount didn't carry them. Any places on the internet?
    Re: Bump Stops
    try homedepot or lowes
    K&N air filter, Whisper air lid, magnaflow LT1 cat back, and magnaflow high flow cat, pacesetter headers, silverstars<br /><br />more to come soon<br />but for now im out of money
      Re: Bump Stops
      No kidding. Had the rear in the air a few days ago do to the brakes. Mine were the same way. Completely shot to hell, nothing left to them.
      If I find a replacement I'll let you know.
        Re: Bump Stops
        k. thanks i need them bad
          Re: Bump Stops
          I got my replacements from the local Chevy dealer.
          Doug<br />1996 Camaro RS M5 Y87<br />SLP Bilstein shocks, Eibach springs, 1LE frt/rear sway bars
            Re: Bump Stops
            autozone has some energy suspension universal ones, try them. You probably asked for fbody specific ones I take it?
            http://www.bowtiev6.com/
              Re: Bump Stops
              nope. gave them the number off the internet and they said they wouldn't be the same. so i think i am going to call gm and get the part number then get the from gm parts direct
                Re: Bump Stops
                Check these out, I suck and don't specifically know what ours look like but here is a list of bump stops available through Summit Racing Bump Stops
                Let's flip a coin. Heads I get tail, Tails I get head.
                  Re: Bump Stops
                  idk if ours have 2 bolts or 1, but these look like it http://store.summitracing.com/partde...5&autoview=sku and its easy enough to make them single bolt with a drill
                    Re: Bump Stops
                    my 97 firebird is a 2 bolt bump stop
                      Re: Bump Stops
                      search the junkyards, I got a good set off a 3rd gen
                      or use part # 9.9137 for the poly ones(probaly take a alittle modifying to fit)
                        Re: Bump Stops
                        I just recently replaced mine. You can use the ones off of any 3rd gen Fbody. They are a direct swap and will not cost you more than a couple of bucks. The stealership wants almost 30$ a piece. I got three from a junkyard for free and they are great.
                          Re: Bump Stops
                          i got mine from the stealership for $20 each
                          96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
                            Re: Bump Stops
                            YOu might as well give them your wallet :(
                            Car expresses who you are. If you have a ****ty car, you must be a ****ty person;)<br /><br /><a href=\"http://www.cardomain.com/ride/995979\" target=\"_blank\">http://www.cardomain.com/ride/995979</a>
