so i need a new sway bar obviously.. and i called the junk yard, and my car has the upgraded performance and handling package i guess.. i dont know if thats an upgrade or just on because it needs it being a convertable and all. i can get a coupe sway bar easy and cheap, but if the guy working at the junkyard is right, what in the hell do i do, should i just order a 31" to be on the safe side. im honeslty clueless...
Sway bar broken on my conv.
Re: Sway bar broken on my conv.
How did you break your sway bar, front or rear? Are you talking about and endlink? Just curious.Last edited by ssms5411; 07-19-2007, 08:00 PM.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
i don't think being a convt makes a difference on the sway bar, in either case just find one off an SS or ws6 they are better from what i understand.
and the handling package i would think is the 1le package you can just look at your spid label for that rpo code.Last edited by David8399; 07-19-2007, 10:29 PM.96 camaro auto base model<br />slp cai<br />pacesetter headers<br />flowmaster catback<br />35th anniversary ss wheels<br />richmond 3.73<br />98+ ss spoiler<br />hypertech 160 degree thermostat<br />transgo shift kit
Is this the front or rear sway bar? Our convertible bars are the same as the coupe so don't worry about that. Also do you still have stock shocks and springs? I only ask because this dictates what size bar I recommend you replace it with.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Do you have a pic of this? I'm kinda interested in seeing it.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by T-PunkDo you have a pic of this? I'm kinda interested in seeing it.
I have broken a few endlinks but once I went to poly/thicker metal ones, no problems.
Originally posted by Robb625so i need a new sway bar obviously.. and i called the junk yard, and my car has the upgraded performance and handling package i guess.. i dont know if thats an upgrade or just on because it needs it being a convertable and all. i can get a coupe sway bar easy and cheap, but if the guy working at the junkyard is right, what in the hell do i do, should i just order a 31" to be on the safe side. im honeslty clueless...
This post tells me nothing:
(1) V6 cars DO NOT have any factory "suspension upgrade". And NO, Y87 is NOT. Is this a V6 or not?
(2) Front or rear?
(3) Is the bar or endlink broken?
(4) What year?Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Front sway bar of a 2000. I called the dealer, i gave the vin and the guy told me i had a package that used a bigger sway bar. its broke right at the end of the bar, dont know how, i just bought the car a week ago. sorry bout the lack of info, im still a newb.
Originally posted by Robb625Front sway bar of a 2000. I called the dealer, i gave the vin and the guy told me i had a package that used a bigger sway bar. its broke right at the end of the bar, dont know how, i just bought the car a week ago. sorry bout the lack of info, im still a newb.
No V6 had an option for a bigger front sway bar. 2000 V6 only came with a 28mm, with a 15mm rear.
Do you have a V8, or the dealer is an idiot.Robert - owner www.FirebirdV6.com/CamaroV6.com
Raven
Front is 28mm but the rear is 17mm on 93-97 v6 cars.
To the original poster, is it the horizontal bar that is broke or is the it vertical part coming off the end. That vertical part that attaches to the car is the end link.Last edited by T-Punk; 07-21-2007, 09:49 AM.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
