heater hose mod help please!! - FirebirdV6.com/CamaroV6.com Message Board
  • heater hose mod help please!!
    ok well i tried to go for the heater hose mod yesterday with a friend in his driveway, but his dad started *****ing at us becuase he didnt think the mod was legit and was dangerous. He kept telling us were gunna need a spring or shock compressor, so on. We ended up not doing it becuase it wasnt worth the ***** out. So today im gunna try it at my other friends house, where he has a good jack setup, and such.
    I took a picture of the heater hose i am gunna use( 3 feet long, 3/4 inch inside, and 1 inch thick all together, red semi squishy heater hose)
    My questions... Do i need a compressor at all? Do i need to take off the rear swaybar? I have seen the write up and all, but will there be any pressure on the shocks or springs when i disconnect them, like during this step right here.....
    ----5. Use a wrench with a 21mm socket (or a lug nut wrench) and unscrew the bolt that holds the shock on.
    -----6. Make sure the rear is supported by the jack and pull the shocks away from the bolt hole
    Car: 1994 firebird
    Thanks in advance guys.
    Re: heater hose mod help please!!
    do search, there is a write up on it, it has a link to a ls1 forum where they got step by step pics on how to do it
      You think i dont no that. Who do u think got it stickied on this website anyway?
      http://www.ls1tech.com/forums/showth...1&page=1&pp=20
        http://forum.camarov6.com/showthread.php?t=82033
        ^hmm...no compressor mentioned there. No, the shocks won't explode when you take them off the rear axle..they can be compressed by hand
          thank you
            Yup. It's easy as pie. Your friends dad didn't know what he was talking about here.
