new shocks - FirebirdV6.com/CamaroV6.com Message Board
new shocks
  • new shocks
    So my camaro needs new suspension... I have no idea what I am doing. I would like better handling and will give up comfort. I'm not sure what to replace (springs/shocks) I have looked around and found a couple that I seem to like and are relatively cheap, under $500 for a set. However I have no idea what else I’m going to need, if these are even worth getting and where to buy them
    http://www.hawksthirdgenparts.com/in...ROD&ProdID=816
    http://www.tirerack.com/suspension/s...s-A-Just+Shock
    thanks for any help
    Re: new shocks
    the first set of shocks in the first link are good but i wouldn't pay that price. Here is a site that is alot cheaper with the same shocks.
    http://www.ws6project.com/user_stor/...224592288c1b3e
      Re: new shocks
      Bilstien. Springs optional, poly bushings advised.
        Re: new shocks
        so with the shocks from ws6project.com i don't need springs or am i just using the stock springs? and if i need new ones where/what should i get?
          Re: new shocks
          i wouldn't get springs unless your lowering. and ws6store they are just the shocks. But i heard the bilstein hds are on national backorder. so you might want to check with whoever you order them for incase they are.
            Re: new shocks
            o and i would either get konis or bilsteins those would really be the only ones worth spending your money. remeber you get what you pay for. i always live by that statement.
              Re: new shocks
              if you are going to go ahead and get some after market shocks for better handlingp properties. I highly recomend getting some aftermarket springs that have a stiffer spring rate. They will give u alot better handling with the new shocks, will look alot better on your car giving u about a 1 inch drop. Just my oppinion.
                Re: new shocks
                i'm still not sure why the bilstein HD's are so much better than the other shocks. the Gas-A-Just here: http://www.performancecenter.com/pro...ET/1999/Camaro
                and everywhere else i see it keeps you "glued to the road" and are cheaper because the rear ones are only $35. The HD's say they are also for minor off road use. i'm looking to spend under $400 on new shocks and am not sure what to buy
                  Re: new shocks
                  i would go with bilstiens, people with fbodies, beamers and more go with this company and they outperform alot of other stuff. They are good shocks.
                    Re: new shocks
                    i just put the slp bilsteins and eibach lowering springs in like 2 weeks ago. couldnt be happier. hugs the road like a champ. it does take bumps a little harsher though but its not bad.
