hey guys, once again I have a question. My brother's car is at the dealership right now getting a new rearend, the mechanic at botnick told him that he had to swap my brothers axles into the new (used) rearend because the bolt pattern was different, is there any chance a z28 would have a diff bolt pattern?
V6 and V8 Bolt pattern
Re: V6 and V8 Bolt pattern
Their the same, I think the guy is trying to get more money out of him.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
Originally posted by ssms5411Their the same, I think the guy is trying to get more money out of him.
we had thought the same, but after some research i found that the center piece between the lugs sticks out fiurther on 99-02's (98's still remained the same) the new rearend was off a 00' V6 . . . and that conflicted with his stock rims.. so that was the problem
If your talking about the hub, all you do is use a dremel and grind the hub down a little. Thats what I had to do worked perfectly.08' L76 6.0L 4X4 Chevy EXT.Cab LTZ Vortec MAX with Snug top cover, Dynomax exhaust,Hptuners& K&N intake
