ok right now i am running 225/60r/16's on my car and was wondering what size street tires are the best! would 215's bew better or maybe the 235's?? just wondering??
Best Tires
Re: best tires?
If you're talking about drag racing the wider the tire the more rubber you will have in contact with the ground; thus better traction, but more friction.
A lot of people run 245s on their stock rims without a problem.
Also on a side note the softer the tire the "stickier" it will be meaning more traction, but will generally wear out faster.
Re: best tires?
I personally wouldnt run less then 235 on an F-body unless your in one of two situations
1) its really wet where u live...i.e rains alot, always wet roads
2) if its a winter tire.
wider tires offer better grip and traction in dry weather...but much crappier traction in wet weather.
Wider tires do offer better handling capabilities.
Re: Best Tires
Originally posted by Kronic Budzi would never buy tires smaller then 245 on a fbody, i have 275/40/17 Riken Raptor all around and like them alot. $500 for all 4 mounted..
fbird97 if your thinking to get wider tires, and smoothness it's not an object go for it. I admit that every car may react different to other sizes.Camaro99\'3.8, original spoil package (no body mods...PROUDLY), K&N, Lid 3800II, SLP CAI, Flowmaster, Z28Chrome Tips, 180* Thermostat.
Re: Best Tires
well i did go out and buy some bad *** fudla 245/50/zr16's, these things hook up like no other, i havn't tried yet, but i might not even be able to do a burnout!!! i punch it to the floor comeing around corners and it doesnt slide, doesnt squel it just striaght tears up this little town of mine!!!!
Re: Best Tires
Originally posted by fbird97well i did go out and buy some bad *** fudla 245/50/zr16's, these things hook up like no other, i havn't tried yet, but i might not even be able to do a burnout!!! i punch it to the floor comeing around corners and it doesnt slide, doesnt squel it just striaght tears up this little town of mine!!!!Originally posted by kalaI'll have buttsecks with Richard Simmons!
TEAM BLACK!!!
parting her out
Re: Best Tires
Originally posted by crushedoutDo you mean Fulda? If so I had those when I first put rims on my car. They were awesome. I would dump clutch at 4500RPM and it would just chirp the tires and go. I hit a 90degree turn at 45MPH and made it, at 55 the *** end came loose on me. The rubber was so soft that a year later I had to replace them.
