so I put a new power steering on and it works fine but there is a whine like a supercharger might have. That would be fine if I had a supercharger but I don't. any ideas. bad pump. too tight belt?? what
pump
Re: pump
My power steering pump whines like that when a load is put on it at RPMs above idle (like accelerating from a stop, into a corner). It has been doing that for years. Converting to Valvoline Synthetic power steering fluid lessened the noise but did not totally eliminate it. I'm not going to worry about it until the noise gets uncomfortable or unbearable, or the pump stops working.Now Playing: \'99 Pewter Firebird, stock, bone stock, and nothing but stock, so help me God!<br />Comming attractions: K&N Filter, Lid Mod, Intake Bellows Smooth Pipe Mod.<br />I dream about: Forced Induction (TC or SC) or NOX (or both!)
Re: pump
You may have air in the line like stated before .Check to see if its full too. The hot and cold mark is basically car on car off, respectively. To bleed air out, with the car running, just keep the cap off and turn the wheel lock to lock like 4 or five times. Then re-check the fluid level.
