lca 1LE bushings help! - FirebirdV6.com/CamaroV6.com Message Board
  • lca 1LE bushings help!
    hi everyone,
    i just got a pair of stock boxed LCA's and 1LE bushings. i read all the stickies and went online but couldn't find any instructions on how to take the old bushings off and put the new 1LE ones on. can any please help?
    thanks guys
    Re: lca 1LE bushings help!
    Originally posted by gooftroops
    hi everyone,
    thanks guys
    Maybe that's because you CAN NOT buy 1LE bushings seperately. They ONLY come on 1LE LCA, and they are NOT boxed.
    You don't have 1LE bushings.
    Raven
      i bought the boxed lca's seperately and the bushings are moog which are equivalent to 1LE bushings. either way how i got them doesn't matter. i need help taking off the stock ones and putting the new ones on.
        Not completely true. The moog bushings are actually the same thing GM used for the 1LE cars. The arms were not boxed though. You have to have the bushings pressed out and then have the new ones pressed in. There are other ways of persuading them out and into place but a press is the best and easiest way.
          And where is the documentation for this?
          Raven
            I believe you probably read somewhere that someone said they were virtually the same thing (which they are, since they are both just hard rubber bushings) but i never remember reading that 1le bushings were literally moog. They may be I suppose... but I doubt it.
            Visit My F-Body Page
              moog aren't actually 1LE bushings but theyre equivalent in that they have the same design and rigidity and made from hard rubber. is there any other way of getting the old ones out and putting the news in other than a press being that i dont have one? any ideas?
                you might be able to set up something like this setup using a bench vise and couple of sockets....
                http://dodgeneon.net/images/energy/en4.jpg
                i'd just take it to a shop myself...
                  looks good. thank you for the idea. :work:
                    17 hours ago
                  • Doodler
                    97 Camaro base with expensive sounding noises
                    by Doodler
                    Still trying to find oil leak
