Sway Bar Bracket - FirebirdV6.com/CamaroV6.com Message Board
Sway Bar Bracket
  • Sway Bar Bracket
    My car has been makeing a weird thump when I go over speed bumps, that is when I mainly noticed it. I decided to check the sway bar linkage thought it might be lose. That was not the problem, the bracket that the sway bar bolts to where the large front bushing is on the passenger side broke. Anyone know the part # or proper name for this piece. IT is not the U shape bracket that goes around the sway bar but the Metal piece that bolts to the frame of the car.
    ..Kevin
    Re: Sway Bar Bracket
    can you tell which piece you need from this diagram?
    2000 Camaro 3.8 v6 M5
    Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
      If I am reading the diagram correclty it is part #39. I love that breakdown!
      I forgot to say this is on a 2001 Camaro Conv.
      ..Kevin
        ok, the part number for 39 is 10164141 www.gmpartsdirect.com has it for $10.25 plus shipping
          Thank you for the help, I will order the part right away. I'm glad I found what was makeing the noise!
          ..Kevin
