Shimmie - FirebirdV6.com/CamaroV6.com Message Board
Shimmie
  • Shimmie
    I have not had a chance to try to look into this so I figured I would get a few opinions. When I am hitting my brakes to slow down my steering wheel used to shake really bad, I figured it was my shocks since they were leaking. So I replaced the shocks. The shimmie went away except for at around 70-75 when I would hit the brakes. But now it is back when I hit my brakes when going anywhere over 30. The steering wheel doesn't shake as bad as it used to. So I was wondering if it could be the calipers are sticking? I have also heard that the back brakes could cause that to happen but have never seen that personally. Anyone ever experienced this or have any suggestions on where to start looking? The car has discs on front and drums in the back.
    Re: Shimmie
    yeah I've had this before several times and it was warped rotors. I finaly got some kvr rotors and haven't had any problems since
    2000 Camaro 3.8 v6 M5
    Flowmaster 80 series muffler, B&M ripper shifter, SLP grille
      Re: Shimmie
      Chances are it's either built up material from the pads on your rotors or, more likely, warped rotors. Try bedding-in the pads again to see if that helps. Other wise look into turning the rotors or getting new rotors.
        Re: Shimmie
        yea you need to get your brakes done. Either have the rotors turned and get new pads, or get new pads and rotors
        http://www.bowtiev6.com/
          Re: Shimmie
          warped rotors. have them machined (15$ per rotor at murrays) and you'll be good. try just the front two first. if that dont work try the back two.
            Re: Shimmie
            I have new rotors and pads, they are both EBC. It was hardly noticeable at all when I first installed the new rotors and pads. Only felt it a little when slowing from highway speed but now it has become worse, and does it even around 35 MPH. So I am thinking something else is causing the shimmie. The old rotors were machined one and it did it worse with them then with my new rotors(at least for now).
              Re: Shimmie
              I think you need to get under there and look for any possible broke or loose suspension pieces, also have your front tires balanced.
              Originally posted by kala
              TEAM BLACK!!!
              parting her out
                Re: Shimmie
                Yea, definately shouldn't have that kinda problems with new rotors/pads. Take Crushed's advice and go poking around in there to make sure everything is working.
                  Re: Shimmie
                  Yea, I think this weekend I am going to pull the rotors and see if I can find anything loose or broken.
                    Re: Shimmie
                    I have been told it could be steering caused(such as my rack and pinion is worn out), as anyone ever heard of that happening?
                      Re: Shimmie
                      when your driving and turn does the wheel ever bind up on you?
                      TEAM BLACK!!!
                      parting her out
                        2 days ago
                      • Doodler
                        97 Camaro base with expensive sounding noises
                        by Doodler
                        Still trying to find oil leak
