Ok I'm still toying with suspension mods, Im having a hard time deciding what to get and trying to save money...Is it ok to replace just the rear shocks? I have stock suspension right now, and I was thinking of just putting in single adjustable koni's in the back...I think my front shocks are fine, so by replacing the rear ones I can adjust them for when I go to the track and when Im on the street...or would this be a bad idea and just kill my handling?
shocks
shocks
Project Cars | How To Guides | Scratch Repair | Synthetic OilTags: None
Re: shocks
I know of some people that have done it (Not to F-bodies), and they didn't report any probs. You'll probably notice a difference in how the car reacts when the front tires hit something and when the rears hit something (like a pothole).
Re: shocks
Originally posted by DeuceXI know of some people that have done it (Not to F-bodies), and they didn't report any probs. You'll probably notice a difference in how the car reacts when the front tires hit something and when the rears hit something (like a pothole).
Re: shocks
Depends on how you have the shocks adjusted. "Harder" will help keep the car from squatting in the rear when you take off, but you'll feel bumps more, while softer will increase how much you squat while lessening the feel of the bumps.
Re: shocks
I think if you were going to go with shocks in either the front or back, I'd probably do the fronts. There is a guy running a Z28 in autox around here and he's running Koni yellows in the front and bilsteins in the back. Stock springs. That's also another option. Best advice I could give is just wait until you have enough money to do it all at once, and GET AN ALIGNMENT after it's done. You'll be much happier having it all done at once rather than partially. Just my $0.02. Good luck with it!
