ok just got pro kit and kyb gas adjust shocks, when i lower it is it going to throw off my alignment? are my tires going to wear evenly??
lowering question
Re: lowering question
yes it will throw off your alignment, and no your tires wont ware evenly. anytime you change the suspention hight ect you need to get it realigned. and trust me you dont want to put it off. a bad alignment will eat front tires like candy, i cranked the torsion bars on my ZR2 up about an inch and let the alignment go for about a week and i was horrified of what it did to my ne set of BFGs, it wore alot of tread off the outside of the tire. lower it and get an alignment ASAP
I have the same setup as you, and I'm sure you'll love it.
Anyways, when I got mine a few years back I did a search on here and found some alignment specs that worked for others with similar setups. I printed them out and took em to the shop and they followed those specs.
